887W router IOS 15.2(4)M
DHCP snooping doesn't appear to be working. I have it all set up but the bindings database won't populate and basically all DHCP traffic is allowed. The server is on a switch connected to FE0, and I'm basically just trying to regulate the wireless clients from the built in AP. I tested by removing the trusted state of FE0 and can still get DHCP ACK from any wireless client. It seems like the wireless AP is just bypassing the snooping
Router#show ip dhcp snoop
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
DHCP snooping is operational on following VLANs:
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is enabled
circuit-id default format: vlan-mod-port
remote-id: xxxx.xxxx.xxxx.xxxx (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface Trusted Allow option Rate limit (pps)
FastEthernet0 yes yes unlimited
Custom circuit-ids:
Router#show ip dhcp snoop data
Agent URL : ftp://xxxxxxxxxxxxxx/dhcpsnoop.txt
Write delay Timer : 300 seconds
Abort Timer : 300 seconds
Agent Running : No
Delay Timer Expiry : Not Running
Abort Timer Expiry : Not Running
Last Succeded Time : 00:04:00 UTC Fri Aug 14 2015
Last Failed Time : None
Last Failed Reason : No failure recorded.
Total Attempts : 2 Startup Failures : 0
Successful Transfers : 2 Failed Transfers : 0
Successful Reads : 0 Failed Reads : 0
Successful Writes : 2 Failed Writes : 0
Media Failures : 0
Router#show ip dhcp snoop bind
MacAddress IpAddress Lease(sec) Type VLAN Interface
Total number of bindings: 0
