08-14-2015 07:58 AM
I started working for a new company and they have a few site to site VPN tunnels setup between a few ASA 5520 firewalls; They are running version 9.x code. In looking through the configuration on the firewalls I noticed they have static routes configured on the firewalls to route the interesting VPN traffic through the outside interface with a next hop of that particular firewalls internet gateway. I've setup many site to site VPNs in the past and i've never used static routes to do this so i went ahead and removed the static routes. Turns out, that broke the site to site vpn. Why would static routing be required for a site to site VPN? That's what the crypto map statements are for and they look fine but for some reason they aren't being used?
Example:
If I'm trying to reach 192.168.63.0/24 across the VPN then there would be a route configured on the firewall like this:
route outside 192.168.63.0 255.255.255.0 1.1.1.1 (where 1.1.1.1 = the internet gateway).
Thoughts?
Solved! Go to Solution.
08-14-2015 08:16 AM
"Why would static routing be required for a site to site VPN?"
Well, you would need static route, because if your another static-route would take precedent over follow the example.
Let says: you have this route “A” as such: "route inside 10.0.0.0 255.0.0.0 10.0.0.1"
Now you have a remote-lan segment as via a tunnel: 10.0.10.0/24
If you don't have a static route to default-gateway address as such: "route outside 10.0.10.0 255.255.255.0 1.1.1.1"
Then naturally ASA would assume to route all subnet 10.0.0.0/8 to inside the network, because your route “A” and crypto engine never going to catch that taffic for encryption.
Hope that answer your question.
thanks
Rizwan Rafeek.
08-14-2015 08:16 AM
thanks
Rizwan Rafeek.
08-14-2015 08:17 AM
You're absolutely right, there's a summary route pointing all 192.168.0.0/16 traffic through the inside interface. The more specifics would then be required to route that traffic through the tunnel. Good call. Thanks for pointing that out for me.
