08-18-2015 03:48 AM - edited 03-17-2019 05:26 PM
I have a deployment with CUCM 9.1, CUCIMP 9,1 and Cisco Jabber 11.
I'm able to start a share desktop session from an IM chat/chat group with 2 or more participants. When I try to share desktop with an active call (2 participants), i've got no problem. When I try to share desktop with more than 2 participants, the share desktop button is greyd out, making it impossible to share the desktop.
My questions is:
Can you share your desktop with more than 2 participants when you have an active call?
Regarding the release notes of the Cisco Jabber 11, it only mention with the IM group chat:
Solution:
We were using DSP Resources for videoconferencing and IOS DSP Resources doesn't support content sharing (BFCP).
There are two options:
07-27-2016 08:17 AM
Did you fixed the issue? I'm facing the same issue...
Ricardo Guita
07-27-2016 08:26 AM
Hi Ricardo,
07-28-2016 12:53 AM
Hi Filipe,
Are you using soft or Desk Phone?
Thanks (Obrigado)
Ricardo
07-28-2016 09:45 AM
Hi Ricardo,
Hope you're doing well.
I've just tested with versions 11.6(2) and 11.7 (release today to CCO).
This is the tests result:
Jabber 11.6(2):
Jabber 11.7:
So I believe that was an issue on the Jabber 11.6 release.
(Cumprimentos)
