CUCM 10.5 with jabber 11 login and search
Hi ,
I need to confirm the login and search points for jabber
I have jabber 4 win and jabber 4 iphone
CUCM is integrated with LDAP with port 3268 that 389 was causing troubles
I'm using xml file with these settings:
 <Directory>
   <DirectoryServerType>EDI</DirectoryServerType>
   <DirectoryServerType>BDI</DirectoryServerType>
    <PrimaryServerName>x.x.x.x</PrimaryServerName>
   <SecondaryServerName>y.y.y.y</SecondaryServerName>
   <BDIPrimaryServerName>x.x.x.x</BDIPrimaryServerName>
   <BDISecondaryServerName>y.y.y.y</BDISecondaryServerName>
   <ServerPort1>3268</ServerPort1>
   <BDIServerPort1>3268</BDIServerPort1>
And on service profile setting on CUCM on Directory Profile
I have checked User Data Service (UDS) for directory integration which mean that you can use UDS for directory searches without selecting any primary, secondary, or tertiary servers. Clients connect to UDS using DNS/SRV.
Now
Is my jabber login is done through LDAP and search is done through UDS
And If I need both login and search to be done through UDS, I should modify xml file and not to mention ldap
Or Jabber will always login through ldap authentication because CUCM is integrated with LDAP
Only My hope is not to rely on ldap communication with all users. Only CUCM can reach ldap. then all users should login and search through UDS on CUCM without any need to contact LDAP !!
6 Replies 6
Jaime Valencia
Go to your users, if they say LDAP active, and you have LDAP authentication configured, they will log via LDAP, if they say local users, they will log via UDS.
Whether you want your users to use LDAP directly, or use UDS, for directory seach, that's a whole separate deal
java
if this helps, please rate
Hi Jaime,
thanks, I'll try to delete ldap authentication and check the login again
Also I think after "use UDS check box" checked in service profile. Users are searching directory using cucm. If I uncheck it. They use what xml say to search which is ldap. Am I correct !!
If you want to use UDS for authentication, you need to have this line in your XML file.
   <DirectoryServerType>UDS</DirectoryServerType>
and you need to delete these two lines
Now, you need to make sure that authentication and contact resolution are done using the same service (either both LDAP or both UDS). If you start mixing them, you will have problems in user status, desktop sharing, and even resolving names to extensions.
No, that is completely wrong, such setting is used only for contact resolution source, not authentication during the login.
java
Hi Jaime,
I just checked my notes and found that I am mistaken and you are right. This setting for contact resolution and directory lookup. UDS authentication is enabled in UCM and will work if the client is using local enduser account for login.
Thx for catching this and apologize for the confusion I made :)
Thanks for great info
So for directory lookup from UDS . I need to check use UDS on cucm service profile and remove these EDI and BDI from xml file !
At this moment I think I need a web server to host photos and to point to it from the xml file so that users to be displayed with photos. Photos work with ldap fine so I think it'll need this path to be displayed when using UDS
thanks for your help
