attached you will find a draw. I would like to build such a network.
It is important that data transfer is possible in local area through all devices
(printer, telefone, computer).
I have studied this forum about the Cisco IP SLA.
Due to long check of competitor they are not able to get a solution for a second rule to
takeover the standard route policy.
My first question can the IP-SLA takeover the standard route policy?
If yes, what if WAN1 is back online. Does this IP-SLA rule disable itself?
Is a vice versa rule possible.
Is the RV325 able to have these features ? (IP SLA and so on).
Do have the RV325 the capability to handle this problem in all cases ?
I hope this jpges will help to unterstand what I want to build.
Thanks for any help!
