08-18-2015 11:08 PM
Hi all!
I enabled broadcast and multicast storm control on our core router ASR9010 under l2vpn. But in cause of storm router silently drops packets without any log messages. In configuration guides I didn't find any options for storm control logging. In common IOS storm control evenst are logged by default.
Thanks!
Solved! Go to Solution.
08-20-2015 12:32 AM
I can support the request for CSCto76123, this really needs to be done!!
Here's the script, credits to vungurea from cisco. Please rename the script to .tcl
Note we use it in a L2VPN (PBB EVPN) environment.
Short summary how to use it:
1) installation
Copy script to router. Adjust aaa to your needs
mkdir harddisk:/scripts copy <path to script> harddisk:/scripts conf t event manager directory user policy harddisk:/scripts #aaa authorization eventmanager default local commit end
2) Configure environment and run it.
Customize interval and threshold. I use interval 300 and threshold 1
Customize user, adjust to aaa config (may need to create local user)
conf t event manager environment EEM_DROP_CHECK_INTERVAL <interval> event manager environment EEM_DROP_THRESHOLD <threshold> event manager policy stormcontrol-drop-monitor.tcl username <username> persist-time infinite type user commit end
The script logs syslog messages like that:
RP/0/RSP0/CPU0:Aug 20 03:02:19.209 CEST: tclsh[65789]: %HA-HA_EEM-5-ACTION_SYSLOG_LOG_NOTICE : stormcontrol-drop-monitor.tcl: Unknown_unicast traffic exceeded threshold 1p/300s on HDB-HOA02-1234-NCA-GN1-0567 Bundle-Ether10.1234 Exact value: 105
Values from this log message:
threshold 1 packet / interval 300s
bridge-domain name: HDB-HOA02-1234-NCA-GN1-0567
interface: Bundle-Ether10.1234
dropped packets by storm-control: 105
have fun, thanks to Vlad.
Greetings
Mathias Rufer
08-19-2015 01:07 AM
we had the same problem and got an EEM script that logs the drops after opening a TAC case.
Greetings
Mathias Rufer
08-19-2015 01:10 AM
Hi Mathias,
Can you provide me this script? We need to enable logging storm control.
Thanks!
08-19-2015 07:57 AM
hi vladimir,
you can take the script part of this article: https://supportforums.cisco.com/document/93456/asr9000xr-local-packet-transport-services-lpts-copp
you could modify the show command to get the counters, define the rate for threshold and alert as you require.
currently the cli doesn't natively show the rates per AC or PW, but there is a script in the shell for that also, I forgot what the dDTS was that implemented, but I know the (phenomenal) guy that made it from BXL TAC, I have forwarded the question to him to see if he can respond with his details.
cheers!
xander
08-20-2015 12:32 AM
1) installation
Greetings
Mathias Rufer
08-20-2015 12:49 AM
Hi Mathias!
Thank you for the script! Of cource storm control logging feature need to be implemented in the future software leleases. But at this time this script is a way out.
Thanks again!
08-19-2015 07:52 AM
Vladimir,
That is a good point and in fact we are looking at an enhancement to help here. We have enhancement CSCto76123 filed for this. Let me go and see if we can get some focus on getting this enhancement moving.
Until then, the EEM script mentioned is probably your best bet.
Bryan
09-17-2017 12:17 PM
I have improved Vlad's script with new functionality:
Hope you like this script!
Tim
