ISE database oracle - how to access it for RO purpose
I was wondering whether there is any way to access its internal records (database)?
Im interested in creating my own reports couse those given by ISE (predefined) are unsufficient.
any clues?
regards
Przemek
6 Replies 6
There is an API that may be of use to you.  I dont know that you can directly attach to the DB or not.
http://www.cisco.com/c/en/us/td/docs/security/ise/1-4/api_ref_guide/api_ref_book/ise_api_ref_ch1.html
hi,
I've seen it but its quite limited and for me useless
nethertheless THX
regards
Just curious, but what type of information are you looking to get from the DB?
need to create report which presents failed authentication but I want only one record per failed endpoint which is impossible to do on ISE.
so I was wandering whether it is possible to make custom query
regards
try this.  maybe it will fit your needs.
https://raw.githubusercontent.com/bandrel/ciscoisetools/master/uniquefailed.py
thx for the script
I'll try this and give back my feedback :)
regards
