Hi;
You can do a "show interface gigx/x". Check if:
- There are overruns
- There are underruns
Then check for CPU spikes, or high CPU issues. Finally, take a capture on the interface for 100 packets, check the capture and see if you can see the 100 requests, at that point for sure, you should be able to tell that there is a connection issue, but not on the firewall side.
Mike
Mike
