visual voicemail 8841
Bernece Johnson
We are running CUCM 10.5 and are replacing our 7962 phones with 8841s. The phones work fin, except I am unable to get visual voicemail to work on the new phones. Has anyone been able to get this to work?
8 Replies 8
Rob Huffman
Hi Bernece,
I'm guessing the issue relates to this bug;
Documentation : missing configuration steps visual VM on 88xx phones
CSCuq94508
Symptom:
Documentation : "VVM client on 88xx is not supported as a midlet"
Conditions:
Document needs to be updated specifying a note that "VVM client on 88xx is not supported as a midlet"
Visual Voicemail is supported on 8861 phone but not as a midlet.
In order to use VVM, it is required to create additional service and subscribe it to the phone instead of Visual Voicemail service used on other phones.
Workaround:
None
Cheers!
Rob
So there is not other way to configure VVM other hand with a midlet?
I know this post is a bit old, but I was sort of able to get Visual Voicemail working on an 8851 phone.  I can see the messages from the phone but can not get the voicemail to play.  I am hoping someone can help me with that.
To configure Visual Voicemail for 8851 (assuming it will work with 8841 as well) go to DEVICE>DEVICE SETTINGS>PHONE SERVICES.  Click ADD NEW
Service Name: VisualVoicemail
Service Description: XML Version of Visual Voicemail
Service URL: Application:Cisco/VisualVoiceMail
Service Category: XML Service
Service Type: Messages
Service Vendor: Cisco
Parameters:
Parameter Name: call_connect_delay
Parameter Display Name: Call Connect Delay
Default Value: 1000
Parameter Description Call Connect Display
Parameter Name: log_level
Parmeter Display Name: Log Level
Default Value: info
Parameter Description: Level of Logging
Parameter Name: voicemail_server
Parameter Display Name: Voicemail Server
Default Value: IP of the CUC Server
Parameter Description: IP of the CUC Sever.
Hope this is useful for someone.
Awesome! Its working for me..Thank you.
Yes this works on 8861 via new service and subscribe
Hi all,
our VisualVoiceMail works with 8841.
Just configure like described in the manuals I posted before.
TAC found that the route pattern to the Visual Voicemail Reverse TRAP was not Urgent Priority! We just had to change it.
Paul Freiberg
I can not click on the button "Ihave this problem too".
So I let you know I have this problem too ;)
