08-20-2015 12:21 PM
The following Hardware installation guide states taht the air filter on the 15454-M6 AC power supply is replacable, but I cannot find a part number for a customer wanting them.
http://www.cisco.com/c/en/us/td/docs/optical/hardware/15454install/guide/hig15454/hig_15454M6.html#pgfId-824180
"The fans cool the module and guarantees proper operation across the complete operating temperature or output power range. These fans contain replaceable air-filters. The AC power module draws power from the power lines to turn on the ONS 15454 M6 shelf. See Table A-3 for the power specifications of the AC power modules."
If anyone has a cisco or non cisco part number I can give my customer, I would appreciate it.
-mike
Solved! Go to Solution.
08-22-2015 11:36 AM
I found the part number of on Cisco's ordering page. Not easy to find.
15454-M6-AC-FLT=
6 service slot MSTP chassis AC power supply fan filter
08-21-2015 08:45 PM
The 15454 M6 data sheet , listed in Table 7: Ordering Information, indicates the part number for the fan tray filter for the M6 chassis is "15454-M6-FTF".
08-22-2015 06:45 AM
That is the Fan Tray filter, I have already put that on the customer BoM, we are looking for the filter for the AC Power supply.
-mike
08-22-2015 11:36 AM
15454-M6-AC-FLT=
11-05-2015 09:45 AM
