Warning message
Need Traffic Analyzer - Packet Capture from CISCO
Answered Question
Aug 25th, 2015
I am using cisco router, i have created sub interfaces, i am using public IPs - Now i need to check the traffic flow...
I need the below details for the same.
1.Source IP
2.Source Port
3.Destination IP
4.Destination Port
5.Date and Time of Access
I Want to capture the above details from the cisco Router.
What is the solution for this, Can cisco help me in this.
Correct Answer by Mark Malone about 1 year 11 months ago
depending what your hardware/ios is you will need to check what features you have available and what it supports
Most routers are limited that they cannot support SPAN but 3845s can or you could look into using the feature RITE
Some routers also support monuitor capture buffer
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
https://supportforums.cisco.com/document/29616/utilizing-new-packet-capture-feature
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/10570-41.html
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t11/ht_rawip.html
Overall Rating: 5 (1 ratings)
Correct Answer
Mark Malone Tue, 08/25/2015 - 01:30
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 LAN
