08-25-2015 06:27 PM - edited 03-18-2019 11:38 AM
we will be converting small help desk from Centrix phone system to Cisco VoIP. We have CCX 10.6 HA and UCM 9.1. I am wondering in order for us to configure all the agents in CCX and finesse, is there any step by step instructions available on Cisco site? I am more looking for an answer which can simplify the process of creating these agents from scratch. What do I need to do first, second and so on....Thanks
Solved! Go to Solution.
08-25-2015 06:35 PM
Have you looked at the UCCX administration guide:
Refer: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_10_5/config/guides/UCCX_BK_U9F91527_00_unified-ccx-administration-guide-release-10-5/UCCX_BK_U9F91527_00_unified-ccx-administration-guide-release_chapter_011.html
The above guide should have the information you are looking for.
-Terry
Please rate all helpful posts
08-25-2015 06:35 PM
-Terry
08-26-2015 07:44 AM
Thanks Terry...
08-26-2015 06:18 AM
+5 for Terry for pointing to proper documentation.
In summary:
add end user or modify existing end users in CUCM by associating the user's phone to the end user and selecting the IPCC extension field. This step will bring in the user as agent into CCX application.
In CCX assign the agent to skill(s) and team
Associate the phone with your rmuser application user in CUCM
Ensure the selected IPCC DN is set to max calls 2 and busy trigger 1 and no forwarding to VM,etc.
