08-26-2015 06:43 AM - edited 07-05-2021 03:50 AM
We are going to setup a Wireless Network with the following products, we would request you to provide us an accurate answer about their workability
Controller : AIR-CT5508-50-K9
Access Point : AIR-CAP2602I-N-K9 x10Nos
Access Point : AIR-CAP2602I-A-K9 x15Nos
Both the access points having different regulatory domains (i.e. A & N), I am doubtful whether this combination will work or not
Sanjay Kumar
08-26-2015 09:36 AM
From the below table you can find the radios which can su[pport by latest 5508 series WLCs
Hardware/Software Parameter | Hardware/Software Configuration Type |
Release | 8.1.111.0 |
Cisco WLC | Cisco 55xx Controller |
Access points | 1142, 3502, 3602, 1602, 2602, 1702, 2702, 3702, 702, 702W, 1852 |
Radio | 802.11ac, 802.11a, 802.11g, 802.11n2, 802.11n5 |
Security | Open, WEP, PSK (WPA and WPA2), 802.1X (WPA-TKIP and WPA2-AES) (LEAP, PEAP, EAP-FAST, EAP-TLS) |
RADIUS | ACS 4.2, ACS 5.2 |
Types of tests | Connectivity, traffic, and roaming between two access points |
If you want to know the more information please read the below release notes.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn81mr1.html#47548
08-26-2015 10:25 PM
Hi Sanjay,
First of all 2602 AP need to have 7.2.110.0 version on WLC.
I think to support both kind of AP with different regulatory domain you need to configure multiple country code on WLC.
Using multiple country code on WLC is possible ! But there is a limitation. A big one, what channels will you be able to use?
with multiple Country Codes you are limited to the common channels and power.
Don't forget to rate helpful posts
08-27-2015 03:29 AM
Hello
There is a way to change the regulatory domain of each radio in an AP from ROMMON using the RADIO_CARRIER_SET parameter. Cisco doesn't mention it, but I have seen it done by TAC engineer during webex and I tried the procedure myself changing the domain back and forth on a handful of Cisco AP models.
There is a chinese blog which describes it and shows all the required codes for 2.4 and 5GHz radios. I don't know what Cisco thinks about it, so I will not provide the link, try googling for it yourself.
Regards.
