08-27-2015 12:17 AM - edited 03-11-2019 11:30 PM
Hi . I want to know ASA5550 Nat Table Limit connection. i search ASA5550 datasheet. but i can't find NAT table.
Below is ASA5550 . License is default (Premium License)
Cisco Adaptive Security Appliance Software Version 8.4(1)
Device Manager Version 6.4(1)
Compiled on Mon 31-Jan-11 02:11 by builders
System image file is "disk0:/asa841-k8.bin"
Config file at boot was "startup-config"
fw01schgr up 1 year 333 days
failover cluster up 5 years 43 days
Hardware: ASA5550, 4096 MB RAM, CPU Pentium 4 3000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode : CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.06
Number of accelerators: 1
0: Ext: GigabitEthernet0/0 : address is c84c.7522.3972, irq 9
1: Ext: GigabitEthernet0/1 : address is c84c.7522.3973, irq 9
2: Ext: GigabitEthernet0/2 : address is c84c.7522.3974, irq 9
3: Ext: GigabitEthernet0/3 : address is c84c.7522.3975, irq 9
4: Ext: Management0/0 : address is c84c.7522.3971, irq 11
5: Int: Internal-Data0/0 : address is 0000.0001.0002, irq 11
6: Int: Not used : irq 5
7: Ext: GigabitEthernet1/0 : address is 5475.d0f0.4976, irq 255
8: Ext: GigabitEthernet1/1 : address is 5475.d0f0.4977, irq 255
9: Ext: GigabitEthernet1/2 : address is 5475.d0f0.4978, irq 255
10: Ext: GigabitEthernet1/3 : address is 5475.d0f0.4979, irq 255
11: Int: Internal-Data1/0 : address is 0000.0003.0002, irq 255
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited perpetual
Maximum VLANs : 400 perpetual
Inside Hosts : Unlimited perpetual
Failover : Active/Active perpetual
VPN-DES : Enabled perpetual
VPN-3DES-AES : Enabled perpetual
Security Contexts : 2 perpetual
GTP/GPRS : Disabled perpetual
AnyConnect Premium Peers : 2 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 5000 perpetual
Total VPN Peers : 5000 perpetual
Shared License : Disabled perpetual
AnyConnect for Mobile : Disabled perpetual
AnyConnect for Cisco VPN Phone : Disabled perpetual
Advanced Endpoint Assessment : Disabled perpetual
UC Phone Proxy Sessions : 2 perpetual
Total UC Proxy Sessions : 2 perpetual
Botnet Traffic Filter : Disabled perpetual
Intercompany Media Engine : Disabled perpetual
This platform has an ASA 5550 VPN Premium license.
Failover cluster licensed features for this platform:
Security Contexts : 4 perpetual
AnyConnect Premium Peers : 4 perpetual
UC Phone Proxy Sessions : 4 perpetual
Total UC Proxy Sessions : 4 perpetual
ASA5550 limited Connection is 650,000 . Thorughput is 1.2G . conetext is 2/50 . NAT Table connection is unlimited ?? or limited ??
08-27-2015 11:10 AM
The total number of xlates will depend on the IP and port pool available for NAT. Per IP there are ~ 65k ports.
>> You can check the xlate resource usage on ASA by following command:
sh resource usage all
R.Seth
