08-27-2015 03:11 AM
in XR 4.3.2 I used to have :
group mygroup router bgp '.*' neighbor '.*' ! ! end-group
to match all neighbors (IPv4 + IPv6)
but I can't make that work with XR 5.3.1 which seems to check the regexp on "neighbor" very hard:
myrtr(config-GRP-bgp)# neighbor '.*' ^ % Invalid input detected at '^' marker.
the CLI suggests a regexp for IPv4 neighbors, which is accepted :
myrtr(config-GRP-bgp)#neighbor ? A.B.C.D or X:X::X 'RegExp': Neighbor address with strict dot/colon match. Eg. '[0-9]*\..*\..*\..*' router bgp '.*' neighbor '[0-9]*\..*\..*\..*' ! !
but it does not propose an IPv6 one and all I tried were rejected ;)
any idea to match IPv6 neighbors ?
thanks
Mik
Solved! Go to Solution.
09-10-2015 10:54 AM
Hi Mik,
the parser and flexcli team (thanks Sonia) responded to me that you could try this?
group BGPV6
router bgp '.*'
neighbor '::'
address-family ipv6 unicast
end-group
I haven't given this a twirl myself, so i dunno if that is gonna work :)
xander
08-27-2015 04:08 AM
Mik, cant get it to work either, have set this question out to our flex-cli dev team to have a look along.
one of us will report back.
xander
09-07-2015 05:10 AM
same issue with XR 5.3.2 :)
no news from them yet ?
cheers
Mik
09-10-2015 10:54 AM
Hi Mik,
group BGPV6
router bgp '.*'
neighbor '::'
end-group
xander
09-11-2015 02:16 AM
RP/0/RP0/CPU0:rtr(config)#group BGPV6 RP/0/RP0/CPU0:rtr(config-GRP)# router bgp '.*' RP/0/RP0/CPU0:rtr(config-GRP-bgp)# neighbor '::' RP/0/RP0/CPU0:rtr(config-GRP-bgp-nbr)# address-family ipv6 unicast RP/0/RP0/CPU0:rtr(config-GRP-bgp-nbr-af)# ! RP/0/RP0/CPU0:rtr(config-GRP-bgp-nbr-af)# ! RP/0/RP0/CPU0:rtr(config-GRP-bgp-nbr-af)# ! RP/0/RP0/CPU0:rtr(config-GRP-bgp-nbr-af)#end-group RP/0/RP0/CPU0:rtr(config)#commit Fri Sep 11 09:14:15.770 UTC RP/0/RP0/CPU0:Sep 11 09:14:16.154 : config[65900]: %MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user 'xxx'. Use 'show configuration commit changes 1000000314' to view the changes.
that was accepted by the cli at least :)
this really needs to be somewhere in the doc or the cli ;p
thanks Xander
Mik
09-11-2015 03:06 AM
thanks for the confirmation mik, I'll have it documented, besides this forum:)
xander
07-18-2023 02:53 PM
Tested the following wildcard with version 5.3.3 and 7.3.3 and with different platforms, both cases it matches the IPv6 peer address.
neighbor '.*:.*::.*'
