Hi.
I need help with VRF to GRT leaking.
I am running 12.2(33)SRE8 and able to import from GRT to VRF very easy using:
ip vrf solar
rd 65500:200025
import ipv4 unicast map solar_import_global
export map solar_export_global
But as you can see above the export is not allowing "ipv4 unicast map" because IOS do not support it for export, only import.
How can I export a single subnet from VRF to GRT?
Any help appreciated, thanks.
