08-29-2015 04:04 AM
I get VPN old driver to apply for my windows 8.1 , 64 bits but no working ; this a messages , I will try to fixed ,Can you help me
Anyconnect was not able to establish a connection to the specified secure gateway.
velez.efrain@gmail.com
08-29-2015 02:32 PM
09-16-2015 11:33 AM
This discussion has been reposted from Additional Communities to the VPN community.
08-29-2015 04:26 PM
Have other users successfully connected to your VPN previously?
If 'no' user is successful or you just configured this, then you have a problem with your configuration, check your config
If 'yes', uninstall the anyconnect -> restart your computer -> install it, make to run is administrator
Also, do what Dan Lukes said :)
You should not ask in random communities with no relationship to the matter of question.
Please use blue [ EDIT ] button to move this thread to VPN
Thanks.
