08-30-2015 08:43 AM - edited 03-08-2019 01:34 AM
Hello all,
I am trying to come up with a solution, with the ultimate end goal to have different customers traffic segregated via VRFs, but all share 1 ISP breakout default route. This is to save on public IP addresses, so that I dont have to use a separate interface and public address per customer inside a vrf.
This is from an ISP perspective, so the default breakout to the internet, I would like all customer traffic to breakout at this same point as global traffic, but until that point remain segregated within VRFs.
I am hoping to eventually be able to implement a solution where all customers use the same phase 1 for IPSec, but their phase 2 SA's are defined and segregated within VRFs.
Is this feasible? I would imagine the big ISP's implement something similar to preserve public address's ( not 1 public address per customer), aswell as the many private address they would have to route too and separate.
Currently, I am able to reach "our side" of the ISP point to point when sourcing from different VRFs, but I cannot reach the global ip address on the other side.
I have tried many different ways to allow an IP address from within a VRF to reach a global IP address, but cannot seem to find any solution, especially when this takes place from within 1 router.
R2 represents the customers router, R1 represents "our" router, the ISP for the customer, and R3 represents our peer for internet break out.
In these examples vrf shared exists between R1 and R3, but only on R1. vrf CUSTOMER_A exists between both R1 and R2 (in real life R2 wouldn't necessary need to be in a vrf as the connection wouldn't be directly connected, it would just be IPSec into a vrf port-channel.)
R2 (Customer Router): Able to ping 212.182.173.1 which is inside vrf shared when sourced from vrf CUSTOMER_A, but unable to ultimately reach the global ip address.
R2#ping vrf CUSTOMER_A 212.182.173.1
Sending 5, 100-byte ICMP Echos to 212.182.173.1, timeout is 2 seconds:
ping vrf CUSTOMER_A 212.182.173.2
Sending 5, 100-byte ICMP Echos to 212.182.173.2, timeout is 2 seconds:
R1 (ISP Router): Unable to ping global address on the other end of the point to point when sourced from vrf CUSTOMER_A, but able to when sourced from vrf shared.
ping vrf shared 212.182.173.2
If I could find a way for R2 to ping 212.182.173.2 from within the vrf (VRF > global ip) that would solve the connectivity issues.
Here are the full configs for the 3 Routers.
Router 1:
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip vrf CUSTOMER_A
rd 1:2
route-target export 1:2
route-target import 1:2
route-target import 1:1
ip vrf shared
rd 1:1
route-target export 1:1
no ip domain lookup
ip cef
no ipv6 cef
ip tcp synwait-time 5
interface FastEthernet0/0
no ip address
speed auto
duplex auto
interface FastEthernet0/0.1
encapsulation dot1Q 101
ip vrf forwarding CUSTOMER_A
ip address 172.16.0.1 255.255.255.0
interface FastEthernet0/1
ip vrf forwarding shared
ip address 212.182.173.1 255.255.255.0
speed auto
duplex auto
router bgp 65000
bgp router-id 1.1.1.1
bgp log-neighbor-changes
address-family ipv4 vrf CUSTOMER_A
redistribute connected
exit-address-family
address-family ipv4 vrf shared
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 212.182.173.2
ip route vrf CUSTOMER_A 0.0.0.0 0.0.0.0 212.182.173.2 global
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Router 2:
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip vrf CUSTOMER_A
no ip domain lookup
ip cef
no ipv6 cef
no ip address
speed auto
duplex auto
ip address 172.16.0.2 255.255.255.0
no ip address
shutdown
speed auto
duplex auto
no ip http server
ip route vrf CUSTOMER_A 212.182.173.0 255.255.255.0 172.16.0.1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Router 3:
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
no ip address
shutdown
speed auto
duplex auto
ip address 212.182.173.2 255.255.255.0
speed auto
duplex auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
I hope I've described the situation well enough for anyone to be able to offer any help or support, thank you very much for reading and I'd really look forward to any suggestions or different solutions people may know of to accomplish the goal.
Many thanks!
08-30-2015 01:52 PM
Have a look at this document.
https://rekrowten.wordpress.com/2014/02/21/route-leak-between-global-ipv4-table-and-vrf/
08-30-2015 02:33 PM
Hi Reza,
Thank you for providing this link, whilst this does allow a global route to be reachable from within a vrf, it doesn't fit the criteria i'm looking for.
In the above sample the vrf traffic is not segregated over the 192.168.12.0/24 point to point, and not at all inside R2. Whilst the loopback0 or loopback22 on R2 could represent an global internet break out point, the different vrf traffic for customers would have to merge after entering R1.
I'm looking for a solution where the vrf traffic remains totally segregated, only up until the point where internet break out occurs one 1 global interface.
If in the previous link, the vrf ABC on R1 could be made aware of the 192.168.12.0/24 subnet, this would totally achieve that goal (you could ignore R2 essentially.)
Is that possible?
Many thanks
08-31-2015 05:25 PM
Hi all,
I found an exact solution for this situation here:
http://aconaway.com/2011/12/12/vrf-aware-ipsec-tunnels/
This is exactly what I was after, I now only wonder if this is possible, but without the "global shared" interface egress interface being inside a VRF?
Is it possible to have this solution, but with a global interface as the ISP breakout for the separate segregated vrf customer traffic?
Many thanks
