08-31-2015 01:25 AM
I bought a cisco rv320 and with 4-port switch router I created 4 trunks entering the VLAN 1 is not tagged in all four doors and the other VLAN tagged on all switch 4. In sg200-18 I created a door with LAG the usual set vlan and added two trunk ports to the LAG as written in the guide. When I connect a link to a port of the LAG it does everything perfectly, but if I connect both ports the switch stops working like it was unplugged. Why?
thanks
09-01-2015 12:44 AM
From the symptoms looks like you have loop. And ports may be blocked by STP.
It is not completely clear to me what are the exact topology you are trying to achieve.
Aleksandra
09-01-2015 02:23 AM
I thought so at first for the STP and so I disabled the switch SG200 but 'even after disabled have the same problem.
The topology and 'the following:
rv320 router connected to ADSL modem
router rv320 I assigned the VLAN tagged excluding VLAN 1 by default and that 'not tagged on all four doors, creating four trunk ports.
sg200-18 rv320 connected to the router via the 4-port Ethernet dell'rv320.
Basically I want to make a port-channel aggregating 4 ports dell'rv320, which are trunk, in 'sg200-18 creating a trunk link of 4 gig as happens in 2960 or 3750. Clearly nell'sg200 I recreated all present in vlan rv320.
09-01-2015 05:14 AM
If you are trying to do link aggregation between SG200 and RV320 that is not going to work as RV320 does not support link aggregation. Also RV320 does not support Spanning Tree but if it does not support BPDU forwarding we have uncontrolled loop.
In my opinion there is no particular reason for setting up 4G link to the router when the bottle neck is usually WAN side of the router and internet speed.
Aleksandra
