08-31-2015 03:34 AM - edited 03-17-2019 04:09 AM
We are facing Some with Unity Connection server, we are Unable to record voice messages through Any call handler option.
Getting error messages for Java updates.
What need to be done now. Kindly help me out with this.
08-31-2015 05:36 AM
There are many previous threads on this topic, Cisco does need to change the dependency on Java as this gets messed up with every updates. You will have best results with Java 6, so I suggest you downgrade your Java version.
08-31-2015 09:41 PM
Agreed with version 6. This almost works with every Java app. But I see the direction moving towards java consoles instead of away from them
08-31-2015 10:29 PM
09-03-2015 04:01 AM
Worth giving a try and downgrade to version 6.
09-03-2015 04:14 AM
Downgrading to java version 6 is not possible for us.
Is there is any other option?
08-31-2015 12:58 PM
I gave up on using the web interface on Unity and instead use this tool:
http://www.ciscounitytools.com/Applications/CxN/ATM/ATM.html
It works very well for managing audio on call handlers as well as user mailboxes.
08-31-2015 10:35 PM
So instead of running unity on web browser i should download this application?
09-03-2015 02:04 AM
09-03-2015 05:52 AM
Did you follow the directions on setting up UCXN to allow this? There are steps you need to take, service to start, etc.
09-03-2015 02:22 AM
