08-31-2015 07:16 AM
I have an old Continuum DVP eXtra Dense QAM Array that I';m trying to setup in our lab. I can't find any documentation on this device besides the the data sheet. Anyone had the User Guide and/or Configuration Guide for this device? I could probably figure most of it out if I could just login to it. From what I've read, it has a web- based interface, but I have no idea what the IP is currently set to. Thanks in advance for any info.
This is the device: http://www.cisco.com/c/dam/en/us/products/collateral/video/edge-qam-modulators/product_data_sheet0900aecd806d1943.pdf
08-31-2015 06:23 PM
Hi Timothy
I have attached here the System Guide for the device and on-line help manual.
For checking and configuring the IP address of the device, you will need to use the IP Config tool.
I have attached that as well here .
Hope this helps you. Please let me know if you have any other questions.
Kumar Sridhar
09-20-2015 07:55 AM
Kumar,
Hello , thanks for the information . I have continuum dense qam array 24 how can i change the MAPPING configuration ? the array 24 support mpts multicast input?
best regards
09-20-2015 05:29 PM
09-20-2015 08:11 PM
Kumar,
thanks very much for your support.
02-03-2016 09:30 PM
Kumar,
Hello , hope everything is fine there. One question . I am working with a GQAM D9479-1 with no DNCS . I changed to standalone mode and trying to passthrough
clear air program from asi 1 in to rf1 output do you know the craft command ??
regards,
08-30-2016 06:25 AM
Hello, I
have XDQA 12 channel Eqam modulator. Is there any chance to
configure it to support 8Mhz bandwidth for EU transmission? Thanks
08-31-2016 08:10 PM
I think the bandwidth can be set to 7 MHz or 8 MHz if the QAM encoding type is ITU-A. But I don't know if the QAM encoding type is configurable or comes configured from the factory.
09-21-2016 08:44 AM
Hello, kusridha
I have an Continuum DVP eXtra Dense 24 QAM Array
the xdqa 24 is working, let me know that more is needed to put it to work, send udp video format, but not work, I use it with cat 5 wire. Gbit. Conection.
Please any help, I would be very grateful.
odalis.
09-21-2016 04:05 PM
Please check the attachments to my previous responses. You can use the system guide and on-line help files for configuring the device. You can use the mapping assistant tool to map the UDP streams at the input to the RF channels at the output.
Kumar
09-25-2016 04:26 PM
Hello, kusridha
thanks for the reply,
I'm sending a udp signal to the DVP eXtra Dense-24 to test,
I have attached a picture of DVP eXtra Dense-24 measure link.
help_online, it seems to be DVP eXtra Dense-12 channels, I read, but I found no answer to the problem.
I am very grateful for your prompt help, thanks.
excuse my English
odalis.
09-25-2016 09:49 PM
Hello Odalis
The picture you have attached shows that the input link is OK. It is up and running. But it is not receiving any UDP packets. Have you set up the IP address for the input port correctly (GbE DQA Gigabit Ethernet (Input 1)) on the Network page? Also, are the UDP packets have destination IP address correctly (same as the IP address of the input port of the xDQA24)? If these are set correctly, then there is some other problem upstream in your network.
I am attaching on-line help file for the xDQA24 here and the configuration guide.
Kumar
09-27-2016 05:35 PM
Hello, kusridha
I read the pdf you sent me and the online-hepl, and I did not see configurations for GbE port, the IP are correct, I tried it on a PC with vlc and works well, I use IP multicast, and put these with the ip-configuring-tool.
I'm using a small pluglable factor, GLC-T 1000Base-T SFP 100m.
it may be that I need a key program to open the UDP port, or licensed program to do this.
I appreciate any help you can give me, I really need this.
sincerely
odalis
09-27-2016 06:11 PM
There is nothing required to open the UDP port. However, you have to do the mapping using the mapping assistant tool through which you can enable or disable the UDP port.
Kumar
09-27-2016 06:36 PM
Hello, kusridha
okay. I'll try and let you know then., Kusridha, you know how much IP use this equipment if it worked?
Thanks again for your prompt response and your help
regards
odalis
