09-01-2015 07:41 AM - edited 07-05-2021 03:51 AM
Need help to find some Autonomous AP and Bridge Basic Configuration Templates and guides
Solved! Go to Solution.
09-01-2015 07:46 AM
Here you go : https://supportforums.cisco.com/document/61936/autonomous-ap-and-bridge-basic-configuration-template
09-01-2015 04:53 PM
Here is a very basic config for a autonomous AP to advertise single SSID
conf t hostname <AP_HOSTNAME> ! dot11 ssid <SSID_NAME> authentication open authentication key-management wpa version 2 guest-mode wpa-psk ascii <SSID_PASSWORD> ! interface Dot11Radio0 encryption mode ciphers aes-ccm ssid <SSID_NAME> no shutdown ! interface Dot11Radio1 channel width 40-above encryption mode ciphers aes-ccm ssid <SSID_NAME> no shutdown ! interface BVI1 ip address dhcp ! end write memory !
Below should give some guidance if you want to set up a wireless bridge.
http://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
http://mrncciew.com/2013/06/13/wgb-with-psk/
Rasika
*** Pls rate all useful responses ***
09-01-2015 07:46 AM
09-01-2015 04:53 PM
Rasika
