Routing
Don't miss this Cisco Catalyst 8000 offer
Labels
Finding accurate answers to your questions and issues is always gratifying, but what if these answers are shared globally across different languages? The Cisco Community team has been working on a proof of concept (PoC) to take Accepted Solutions in...
Kelli Glass by Community Manager
  • 10235 Views
  • 7 replies
  • 16 Helpful votes
I am using a 3750 switch and going through a Sidewinder G2 firewall. Thefirewall only has its startup config on it with and Internal IP address (.1)which will be the internal gateway. My switch has VLAN2 config of .2. I can ping from my switch to the...
I have an ISR4431 router, and related setting:ip access-list standard toGCP10 permit 10.136.0.0 0.0.127.25520 permit 10.136.128.0 0.0.127.25530 permit 128.231.0.0 0.0.31.25540 permit 128.231.32.0 0.0.31.255!route-map toGCPmatch ip address toGCP!route...
Facing issue with VRRP, when upstream router5 initiate traffic for downstream router6 then return traffic is not following VRRP VIP as Gateway. In my case switch2 is master and switch3 is standby.If Router6 initiate the traffic then VRRP working fine...
Hi All,We have a URL which resolves to particular public ip and performance of that website is slow than expected from our office . We have a P2P link from office to DataCentre and from DataCentre it exits to internet. We observed the performance was...
Hello, I built using the packet tracer a simple topology of three routers with ospf routing. I created a tunnel between the two routers that are not physically connected to each other, but I can't ping between one end and the other. I managed to ping...
Hi I'm trying to extended a L2 segment using MPLS L2vpn over GRE. I am able to establish the tunnel and get ospf and mpls adjacency also the xconnect between the peer is up but my 2 test pc cant reach each other. This is my PE3 config.interface Gigab...
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 173 Views
  • 5 replies
