09-01-2015 08:44 PM
Hi Guys,
My network consist of 5 VLANS. All vlans were map into a range of public ip (NAT).
My question is, is there a way where I can map a specific 1 VLAN into a 1 PUBLIC IP address?
Assuming my vlans are 192.168.1.0 /24 - 192.168.5.0 /24 and my public ip range is 200.1.1.0 /29
Can I map 192.168.1.0 /24 into 200.0.0.5 only?
Thanks in advance :)
09-01-2015 10:23 PM
I assume you are using Cisco routers
so something like
ip nat source static network 192.168.1.0 200.1.1.1 /32
ip nat source static network 192.168.2.0 200.1.1.2 /32
ip nat source static network 192.168.3.0 200.1.1.3 /32
ip nat source static network 192.168.4.0 200.1.1.4 /32
ip nat source static network 192.168.5.0 200.1.1.5 /32
Richard
09-02-2015 01:47 PM
what product is this?
09-03-2015 12:57 AM
If you want to map your network 192.168.1.0/24 with one Public IP, please try the following:
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat pool cisco 200.0.0.5 200.0.0.5
ip nat inside source list 1 pool cisco overload
Apply it to the concerned interfaces.
09-06-2015 10:16 PM
Dear,
Below configuration may help you.
interface Vlan1
description CONNECTION TO LAN
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip nat enable
ip nat inside source route-map fixed-nat1 interface FastEthernet0/0
access-list 110 permit 192.168.2.0 0.0.0.255 any
route-map fixed-nat1 permit 10
match ip address 110
match interface FastEthernet0/0
Note:* FastEthernet0/0 is a public ip configured inrterface
Raja
09-07-2015 01:41 AM
Yes you can, if you have a Public IP range, you can map your local ip range to public range.
Thanks.
