09-03-2015 03:43 PM - edited 03-19-2019 10:02 AM
09-03-2015 07:10 PM
Hi Bruno - Just to confirm - do you know you are trying to install un-restricted version? Whats your hardware - has it got sufficient resources to full support the IM&P.
Secondly have you added the presence node in CUCM - IM&P are same as CUCM Sub servers and needs to be added on CUCM pub before installation? If yes, try deleting and re-adding and then try install if it makes a difference.
You can also scroll through installation logs for any error etc.
Also read through the Pr-requisites here:
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/10_0_1/CUCM_BK_I95AD2FE_00_installing-cucm-100/CUCM_BK_I95AD2FE_00_installing-cucm-100_chapter_011.html#CUP0_TK_P8901E0C_00
-Terry
Please rate all helpful posts
09-03-2015 08:51 PM
If you're supposedly installing 10.5(2) why is the error you're posting saying 10.0(1)????
