Webex XML API - How to enable/disable CMR
nathan.a.reeves
Taking a look through the information around the xml api for Webex and I'm having some issues identifying if CMR can be managed via the API.  I see there was notes in the API 8.0 SP11 release notes about this being added but doco seems deficient otherwise.
I can see there's a isEnableCET attribute which points to the possibility of it being CMR related (CET = Cloud Enabled Telepresence), but just wanted confirmation on this.
Nathan
0 Replies 0
