09-05-2015 03:31 AM - edited 03-19-2019 10:03 AM
I need to change the Hub setting for a particular location - do I need to reset anything - Phones-DP's, Resynch etc - Im running CUCM 9.x
09-05-2015 08:05 AM
Yes, changing location either to the device pool or directly on the device will require reset to the phones.
09-05-2015 08:13 AM
Thanks for the reply. I don't want to reset any ddp or phone if I can help it.
but the question was if I change, increase the BW in the location settings and save it- do I need to reset anything for the new BW to take effect?. I thought I saw an icon on pre ccm9.x that was a bandwidth resynch option
09-05-2015 08:26 AM
No need to reset if you increase the bandwidth of location. It will take affect immediately.
09-05-2015 08:12 AM
