09-05-2015 09:53 PM
Hello, there.
This is my first project.
It would be very helpful if someone answer below questions. Thank you in advance.
I want to buy two ASA 5506-Xs.
Before I pay, I just want to make sure that the licenses and equipment are right for my project.
Requirements for this project:
VPN: 3 to 5 site to site VPN connection.
Failover: Active/Standby
Management interface: ASDM
I do not need IPS and subscription etc.
Q1, which one do I have to use?
Seems like one of followings.
Q2, Which license do I have to buy?
Q3, Do I have to buy one base license for vpn and one security plus license for failover each? or buy one security plus license and that gives me Site to Site and failover function?
Q4, Is there anything I have to concern to use ASDM interface?(I know how to config, but I don't know if that requires additional license)
09-07-2015 04:28 AM
06-26-2016 02:27 PM
I just bought ASA-5506X, and the VPN wizards are missing from the ASDM's menu.
At ASDM, the only options at the menu Wizards are:
- Startup wizard
- High availability and scalability wizard
- Unified communication wizard
- ASDM identify certificate wizard
- Packet capture wizard
Any idea why the VPN wizards are not there?
Thanks.
07-20-2017 03:44 AM
You can also buy the below license if you have ASA5506-K9.
"L-ASA5506-SEC-PL="
It is the security plus license for ASA5506-K9 which gives high availability/redundancy and more.
Afaq Ahmad
07-20-2017 03:55 AM
Be careful, on the 5506 you get redundancy, but not what the typical customer expects from High-Availability. There is no
12-05-2017 09:23 AM
What about Any connect license do I need to buy for both or just one?
And what about firepower additional license if I have one?
Thanks.
