09-06-2015 09:04 PM
What is difference between following two module ?
SFP-GE-L= vs SFP-GE-L , one has = to sigh at the end and other don't.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/eol_c51-698060.html
Solved! Go to Solution.
09-06-2015 09:25 PM
For all Cisco SKUs (Stock Keeping Units), the "=" at the end denotes a spare part or item ordered separately.
Without an "=" generally means the exact same item is ordered as part of a parent configuration - for instance, an SFP as an optional part of a switch module.
They are exactly the same physical part.
09-06-2015 09:25 PM
09-06-2015 10:01 PM
Marvin,
Thanks for explanation.
09-07-2015 06:24 AM
You're welcome.
Please mark your question as answered if it has been.
