09-07-2015 10:58 PM - edited 07-05-2021 03:53 AM
I have Cisco Prime and i am getting the following error when i am going to login. I have used IE,Chrome, Firefox but have the same condition.Kindly let me the solution.
Solved! Go to Solution.
09-08-2015 11:55 PM
Create a new shortcut and use the link provided to run the program. Make sure Chrome is in the right location of the folder.
09-08-2015 12:17 AM
This is due to Bug ID CSCuj42438 & CSCuv21820.
IE works. There are workarounds to use Firefox & Chrome.
09-08-2015 01:57 AM
Hi all,
can anyone point to the workaround for Chrome?
For Mozilla I have found this:
on the url type:
about:config
Here in this config page, you will find a list of boolean entries. Search for below two entries,
security.ssl3.dhe_rsa_aes_128_sha security.ssl3.dhe_rsa_aes_256_ sha
By default, these are set to TRUE. But you have to set them to FALSE in order to allow the less secured pages.
09-08-2015 08:10 PM
For Chrome, use this shortcut:
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --cipher-suite-blacklist=0x0088,0x0087,0x0039,0x0038,0x0044,0x0045,0x0066,0x0032,0x0033,0x0016,0x0013
09-08-2015 10:07 PM
09-08-2015 11:55 PM
09-16-2015 09:02 PM
Issue resolved. Thanks Leo
09-17-2015 07:07 AM
Thanks for taking the time to rate our posts. :)
09-30-2015 03:03 PM
Hi Leo,
Is there a risk for the browser's security if we create thos shortcut ?
AL
09-24-2015 07:54 AM
Maybe I'm just really missing something, but when I try to create a new shortcut with the following path it says it can't find C:\Program application.
However, if I just enter C:\Program Files (x86)\Google\Chrome\Application\chrome.exe the shortcut will work fine. So I definitely have the correct path to the chrome app. What am I missing?
09-24-2015 09:52 AM
To make it work you need to put quotes around the file path and name. So put a " in front of C: and replace the " right after the .exe with another double quote character.
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --cipher-suite-blacklist=0x0088,0x0087,0x0039,0x0038,0x0044,0x0045,0x0066,0x0032,0x0033,0x0016,0x0013
09-25-2015 12:25 PM
Ah, thanks kconrad01 that worked!
10-01-2015 07:46 AM
So.. im still getting the error after adding the cipher suites blacklist..
Here is a straight paste of my target destination.
"C:\Program Files\Google\Chrome\Application\chrome.exe" --cipher-suite-blacklist=0x0088,0x0087,0x0039,0x0038,0x0044,0x0045,0x0066,0x0032,0x0033,0x0016,0x0013
It open's Chrome but when i visit Cisco Prime still get the lovely error... any thoughts?
10-02-2015 12:10 AM
Had the same issue when I created the shortcut. Make sure that after you've created the shortcut, go to task manager and ensure all chrome.exe processes are terminated.
As soon as I terminated all the running chrome processes, the next time I used the modified shortcut the pages loaded fine. (Accessing UCCX Admin Pages)
01-21-2016 06:59 AM
Works great for me.
