Here is the situation: (IPv6-LAN) * (IPv4-LAN) * * ...
The content you are looking for has been archived. View related content below.
hello all ,recently i tried to configure VPN site to site with certificate authentication type, i got the certificate signed by a third party autority , and when i did the debugs i got this log :CRYPTO_PKI: bitValue of KEY_USAGE = a0PKI[7]: CRYPTO_PK...
I am trying to get my head around this to make sure i've understood this correctly. Hopefully someone will be able to clarify it for me. 1. As per the below image, I can see that Balanced and security is enabled as a default for NAP in the default...
Hi All,I configured rest-api and cisco asa but when I try to connect through the hhps://cisco-asa-ip:443/api it requires user/pass, so already created a local user but when I try to log in it is complaining from "Authorization Required" The below con...
Hi All, Am using ASA firewall to connect to BT broadband using PPPoE. It works fine now, I want to use the BT home hub as AP. I done the below steps but it looks like am still missing something. * Disabled DHCP server in BT home hub. * Enabled DHCP s...
Hello ,I am experiencing a port forwarding issue.We want a internal server's https web page to expose public access.The thing is - it is still not sucess.1. Other ports are working perfect except 443.2. Tested multiple same internal servers .. only 4...
i am getting error while registering the device FPR1140 running code 9.14(ASA) as : REGISTERING - REGISTRATION IN PROGRESSExport-Controlled Functionality: NOT ALLOWEDInitial Registration: FAILED on Jun 21 2023 10:29:49 UTCFailure reason: Communicatio...
Hi guys, I hope you are doing well. I have a question regarding FTD devices' internal certificate. We have FTDs which are being managed by a FMC. As far as I understood, FMC talks to the FTDs over an encrypted (Https) channel when it wants to deploy ...
I wrote a short howto for getting started with the free Cisco Trex packet generator for device and network testing here.
We are replacing an old Cisco ASA 5525x failover pair with a new FPR1150 failover pair.Everything is setup and running side by side.We cannot replace them in one go, so we have to move vlan by vlan.The configuration is basically vlans with servers an...
Hi,We have a Firepower 1010 that we'd like to move DHCP to from a Windows Server as it's the last server we have left in our old domain now that everything is in Azure AD instead. In order to do this we need to add some DHCP reservations in for devic...
Hi All,I have an ASA runing asdm 6.3(3). I can launch the console from the web page but can't install it. Here is my config:ASA 6.3(3)Windows 7 x32bitsJava 6.0.21ehrn I try to install it I get the followingany ideas?Many Thanks!Arnaud
HejWe have just upgraded our ASA 1150s to FTD software. Before the upgrade we used "call-home" to direct Smart-license registration to our On-Prem smart license serverBut now that we have upgraded to FTD I can not find the option to register our devi...
Subject: How do I perform a basic setup of Cisco ASA 5516-X firewall?Good day from Singapore,I have just bought a refurbished Cisco ASA 5516-X firewall on 17 March 2024 Sunday.How do I perform a basic configuration of this firewall?Any good guides to...
Subject | Author | Posted |
03-19-2024 04:14 AM | ||
03-19-2024 02:53 AM | ||
03-18-2024 02:05 AM | ||
03-14-2024 12:26 PM | ||
03-14-2024 01:32 AM |
User | Count |
13 | |
7 | |
5 | |
3 | |
3 |
