09-09-2015 08:23 AM - edited 03-01-2019 09:16 AM
i was asked to create an event/job that will stop/cancel a job run. has anyone has an example how to automate to stop a job? please advise.
thank you,
warren
Solved! Go to Solution.
09-15-2015 10:16 AM
Hi Warren,
The commandline utility is a separate install (and should've come with your installer files). Please check.
Derrick Au
09-09-2015 08:33 AM
Hi Warren,
There are a couple of ways to stop a job, but first I should let you know I am still on 5.3.X and if you are already on 6.2 then there might be some modifications needed.
1) Create a new job event, and select action Hold/Stop or Cancel/Abort based on your desired
event trigger
2) From the command line,
To hold, sacmd jobhold jobrun_ID
To cancel, sacmd jobcancel jobrun_ID [YES|NO], where YES instructs Tidal to cancel
dependent jobs as well, and NO instructs Tidal to leave the dependent jobs as is on the schedule.
Default is NO.
Perhaps 6.2 users can add an update ;-)
BR,
Derrick Au
09-09-2015 09:02 AM
thanks Derrick.
I create these jobs:
110 - SEERT Delay Utility
120 - SEERT Cancel Job
I run the 110 first and it has the 8037889 job run id then followed by 120. The 120 did not cancel the first job.
The 120 has these items:
Command: cmd
Command Parameters: sacmd 8037889 YES
The 120 job output is this:
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
E:\Program Files\TIDAL\Agent\TIDAL_AGENT_1>
Completed at 9/9/2015 12:00 PM
Please advise.
09-09-2015 11:39 AM
Hi Warren,
Missing jobcancel
ie, sacmd jobcancel 8037889 YES
Command: cmd
BR,
Derrick Au
09-15-2015 05:14 AM
09-15-2015 09:20 AM
09-15-2015 10:04 AM
Hi Derrick,
It looks like there's no sacmd.exe. Is the sacmd.exe on the server where the tidal master is installed at?
Volume in drive E is Data
Volume Serial Number is 0C27-6745
Directory of e:\Program Files\TIDAL
12/12/2014 09:49 AM <DIR> .
12/12/2014 09:49 AM <DIR> ..
12/12/2014 09:49 AM <DIR> Agent
04/10/2000 12:01 PM 19,456 NTEventLog.dll
10/18/2007 11:02 AM 780 oem.cfg
08/17/2010 07:45 AM 905,728 ServiceMgr.exe
10/14/2011 05:04 PM 64,512 TClusUtl.dll
02/09/2006 09:59 AM 740,352 TIDALInst.dll
5 File(s) 1,730,828 bytes
3 Dir(s) 31,586,623,488 bytes free
Completed at 9/15/2015 1:00 PM
Warren
09-15-2015 10:16 AM
Hi Warren,
Derrick Au
09-17-2015 06:50 AM
Thanks for the kudos Warren
The command line utility can be installed at an agent/server, not necessarily at the Master.
BR,
Derrick Au
09-17-2015 05:42 AM
thanks derrick. it looks like the sacmd.exe is not installed. i have requested it to our admin to install it.
