09-10-2015 02:13 AM - edited 03-18-2019 04:58 AM
If I add a 9951 phone as an unmanaged endpoint in TMS (there is no other way as far as I can tell) will it also consume a system license ? I have 25 in total
Solved! Go to Solution.
09-10-2015 03:20 AM
Yes, they do.
They'll be listed either under "Rooms" or "Equipment", depending on your choice, but they will appear in the total number of system licences used.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
09-10-2015 03:20 AM
Yes, they do.
/jens
09-10-2015 03:25 AM
Thanks Jens. Let me take it a bit further
If I add a CUCM system which has a 9951 an SX20 and an MX200 registered to it, what will happen ?
Will it consume 2 licenses (CUCM and 9951 as unmanaged) or the two TP rooms will also consume licenses (4 in total) ?
09-10-2015 08:21 AM
Anything you add into TMS using "Add Systems" will consume a system licenses.
