09-12-2015 07:45 AM - edited 07-05-2021 03:55 AM
Hello Folks,
I want to know meaning of this.
What does optimizedRoaming Rejections means ? Please help.
OptimizedRoaming Stats
802.11b OptimizedRoaming Disassociations....... 2
802.11b OptimizedRoaming Rejections............ 2651
Aniket
09-15-2015 04:59 PM
Refer this, once you enable this feature client connection will be rejected unless RSSI increased 6dBm above the disassociation threshold. Those may be the rejection stat shows.
The client will be allowed to rejoin the AP when the client RSSI value has increased to 6 dBm above the disassociation threshold. For example, if the Data RSSI threshold is -80 dBm, the client will be allowed to re-associate once the RSSI values is increased to -74 dBm.
Rasika
*** Pls rate all useful responses ***
09-27-2016 03:23 AM
So in short, the "OptimizedRoaming Rejections" number counts the association requests from clients with a signal below -74 dBm (if we take your sample values)?
You can also set a timer in the optimized roaming section. This timer is then only for the disassociation action?
03-24-2017 05:57 AM
What is the difference between Optimized Roaming Disassociations and Optimized Roaming Rejections?
I see 0 Disassociations but +20,000 Rejections on 802.11a.
