09-14-2015 04:31 AM
Can any one suggest me that how i can backup the DCNM 7.2 database for a standalone server on NFS /FTP?
what is procedure to take backup on NFS /FTP server ?
Is any dependency to take backup to remote servers from DCNM standalone server (Not in HA) ?
Solved! Go to Solution.
09-18-2015 05:15 AM
DCNM includes a database backup utility in the $INSTALLDIR/dcm/dcnm/bin/ directory. There are 2 versions of the script, one for Oracle and one for postgres databases, and they both can be run from the command line of the server. These scripts will create a database dump file (.dmp) which you can ftp off to another file server if desired.
For reference, here is the documentation on DCNM db backups:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/7_2_x/fundamentals/DCNM_Fundamentals_7_2/fund_dbmaint.html#pgfId-1383271
Eric
09-18-2015 05:15 AM
Eric
