Upgrade to DCNM-SAN Server 7.2(1) - now unable to connect
Chris Tolley
Level 3
Level 3
Following an upgrade of DCNM-SAN to version 7.2(1) when I try to login to the DCNM I get a dialog box with the following error:
ERROR Data Center Network Manager 0 SAN 7.2(1)
Unable to connect to DCNM-SAN server.
The fabric may be loading or discovering. Please try again.
Windows Version: Win2k8 R2 Enterprise SP1
Java Version: Java 8 Update 51
Has anyone encountered this and have some insight into this issue?
Chris Tolley
Level 3
Level 3
Found a solution;
Interactive Services Detection was not enabled. Enabled the service and then restarted the DCNM_SAN and SMI-S Agent services and then it let me in.
I was having the same problem and this fixed it. Thanks.
