09-15-2015 01:47 AM - edited 03-08-2019 01:46 AM
Hi everybody :)
Thanks for an awesome ressource!
Long story short, i've been labbing dhcp snooping and arp inspection. And during i needed extra clients... So i thought i could use a single switch, separate a couple of routed ports with vrfs. Then have the ports ping each other through a second switch with a simple vlan between them. But they cant ping each other. Could someone please tell me what is wrong with my logic here...
I'm running c3560-ipservicesk9-mz.122-58.SE2.bin on a 3560c with the following config:
Vrfs first:
clients#sh ip vrf
Name Default RD Interfaces
cli6 6:6 Fa0/6
cli7 7:7 Fa0/7
cli8 8:8 Fa0/8
Then the interfaces:
clients#sh run int fa0/7
Building configuration...
Current configuration : 153 bytes
interface FastEthernet0/7
no switchport
ip vrf forwarding cli7
ip dhcp client hostname cli7
ip address dhcp
end
clients#sh run int fa0/8
interface FastEthernet0/8
no switchport
ip vrf forwarding cli8
ip dhcp client hostname cli8
ip address dhcp
end
Interface states:
clients#sh ip int brie | i /7|/8
FastEthernet0/7 10.3.76.43 YES DHCP up up
FastEthernet0/8 10.3.76.46 YES DHCP up up
The switch vlaning the two routet ports together:
MiddleSw#sh run int fa0/8
Current configuration : 108 bytes
switchport access vlan 10
switchport mode access
spanning-tree portfast
end
MiddleSw#sh run int fa0/7
end
I have a PC on the same subnet, in the same vlan on MiddleSw that has no problem pinging either of the two routet ports. Leading me to believe that this is not possible, but why? Hope you guys can elaborate :)
Thanks again!
09-15-2015 02:08 AM
Hi Kim,
On the clients switch, when you want to do pings, you will need to issue the ping command including the name of a VRF. Without that, the ping command tries to reach the intended destination using interfaces and routing information from the global routing table which is obviously empty.
So if you want to ping your Fa0/8 from your Fa0/7, you need to issue
ping ip-address-of-Fa0/8 vrf cli7
And in the opposite direction, if you want to ping Fa0/7 from your Fa0/8, you need to issue
ping ip-address-of-Fa0/7 vrf cli8
You always need to keep in mind the VRF in which the ping packets are being originated and from which they need to be routed out. This VRF needs to be specified in the ping command.
Would you mind testing this out and telling us if it worked for you?
Best regards,
Peter
09-15-2015 04:17 AM
Hey Peter :)
Thanks for your reply! Thats exactly what i've been doing, but your suggestion tells me that maybe this aught to work...
Note, addresses changed slightly
FastEthernet0/7 10.3.76.122 YES DHCP up up
FastEthernet0/8 10.3.76.117 YES DHCP up up
The ping:
clients#ping vrf cli7 10.3.76.117
Sending 5, 100-byte ICMP Echos to 10.3.76.56, timeout is 2 seconds:
Success rate is 0 percent (0/5)
But no dice!... Routing information shows:
clients#sh ip route vrf cli7
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.3.76.0/24 is directly connected, FastEthernet0/7
L 10.3.76.122/32 is directly connected, FastEthernet0/7
clients#sh ip route vrf cli8
C 10.3.76.0/24 is directly connected, FastEthernet0/8
L 10.3.76.117/32 is directly connected, FastEthernet0/8
09-22-2015 08:46 PM
Hi Kim,
I apologize for responding so late - it's been a busy week.
Some of the outputs you have posted are puzzling me, for example:
If you were pinging 10.3.76.117, why does the ping say you're pinging 10.3.76.56?
If this was just an error in transcription, can you make the experiment again and check the following?
Looking forward to hearing back from you :)
Best regards,
Peter
