Is it possible to use a variable for File Event directory?
michaelamato
Is it possible to insert a variable for the Directory of a file event? In the below example I would like to replace 'F:\QA' with a variable.
Variable:
  Value:  F:\QA
File Event:
   Directory: F:\QA\Test
I don't think so. I agree it's a pain specifically if you have many file agents and folder locations need to be updated
Derrick Au
Level 4
Level 4
Hi Michael,
As Dinesh pointed out a variable is not possible in a File Event.
Have you tried looking into a File Dependency instead? With a File Dependency you can utilize variables.
Cheers,
Derrick Au
