09-17-2015 06:29 AM - edited 07-05-2021 03:57 AM
hello,
we have a couple of access point Cisco AIR-CAP2602I-E-K9 that are configured as lighweight access point.
can we convert these access point to mesh firmware ?
We need to configure these access point in Bridge mode as RAP or mesh access points as MAP
is it possible ?
kind regards,
Cristiano
Solved! Go to Solution.
09-23-2015 08:00 AM
Good to hear that you are able to solve the issue
Please mark this discussion as correct answered.
09-17-2015 09:23 AM
If the AP is already in lightweight mode (connected to a WLC) you can change the mode to 'Bridge' which is effectively mesh mode, and then set up the AP as a RAP or MAP.
There isn't a 'Mesh' firmware, the options are either lightweight or autonomous. Mesh is only available using a WLC and therefore lightweight AP software.
Hope this helps,
Pete.
09-17-2015 11:04 AM
Document is a bit aged but lots of information is till the same
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-mesh/111451-indoor-mesh-deploy-guide-00.html
09-22-2015 07:44 AM
thank you for your feedback. I was able to reconfigure my access-point as mesh
kind regards,
09-23-2015 08:00 AM
