09-19-2015 03:39 AM
Hi all I am trying to test different tos values between CEs What am trying to test is default traffic which will fall into the routine traffic and another flow which should fall in the critical traffic (tos=160) My access-list looks as below access-list 105 permit ip any any precedence routine log access-list 105 permit ip any any precedence priority log access-list 105 permit ip any any precedence immediate log access-list 105 permit ip any any precedence flash log access-list 105 permit ip any any precedence flash-override log access-list 105 permit ip any any precedence critical log access-list 105 permit ip any any precedence internet log access-list 105 permit ip any any precedence network log access-list 105 permit ip any any interface GigabitEthernet0/1.56 ip access-group 105 in ip access-group 105 out ping 10.3.3.1 repeat 19 tos 160 ping 10.3.3.1 repeat 15 Probe#sh ip access-lists 105 Extended IP access list 105 10 permit ip any any precedence routine log (34 matches) 20 permit ip any any precedence prioritylog 30 permit ip any any precedence immediatelog 40 permit ip any any precedence flash log 50 permit ip any any precedence flash-override log 60 permit ip any any precedence critical log 70 permit ip any any precedence internet log 80 permit ip any any precedence network log 90 permit ip any any The 19 ICMP packets should fall into the critical I have tested this on GNS3 and it worked fine ! Is there something global should be enabled on the PE which is 7606? BR, Mohammad
09-21-2015 09:27 AM
Hello Mohammad
From your setup, is there any QoS settings on the PE for treating the various TOS bits that you are setting. Could you please share the packet details received on the remote CE router. If its a Cisco IOS software, you can use EPC to perform a packet capture to see the packet.
On GNS3, have you tested the pings between the directly connected router or across the l2vpn setup?
Vinit
09-22-2015 01:03 AM
Hi Vinit
Thanks for the kind reply
When I have tested this on GNS3 , it was across the L2VPN and it worked fine (I have used routers 3725) so I do not think there was any issue
By live setup is : my CE is 6509 and my PE is 7606
No special QoS configuration present on both
I have tried to configured mls qos trust dscp and mls qos trust extend on the CE with no luck
BR,
Mohammad
09-22-2015 09:04 PM
Can you share the config of PE router
09-22-2015 09:05 PM
Could you please share the below output from the 7600 PE:
- show version
- show module
- show run
- What is the Core facing module and CE facing module
I think you will have to implement QoS policy to set experimental bits to xfer marked packets across L2VPN. L2VPN and QOS on 6500/7600 are platform dependent features and thus the configs differ with what you test in GNS3 and in live production devices like 7600.
Once I have the above information, i can share some inputs on what configuration can be applied on 7600.
Vinit
09-28-2015 01:04 AM
CE
1 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL04430E1H
PE
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL13442U2W
version
bootdisk:c7600rsp72043-advipservicesk9-mz.122-33.SRE12.bin
PE#sh run | inc mls
mls flow ip interface-full
no mls flow ipv6
mls qos
no mls acl tcam share-global
mls cef error action reset
From the PE side
Vlan 56
Interface G1/13
Switchport mode access
Switchport access vlan 56
Interface vlan 56
Xconnect x.x.x.x 56 encapsulation mpls
From the CE side
Interface f1/13
Ip address 10.3.3.2 255.255.255.0
