09-23-2015 05:42 AM - edited 03-15-2019 05:32 AM
I am installing a new BE6000 device but I can't join ESXi host and I can CIMC. I don't know what is happen. Can you help me, please?
Aristide
Solved! Go to Solution.
09-23-2015 07:41 AM
Have you tried restarting the management network?? Have you verified all the ESXi settings are correct??
09-23-2015 07:41 AM
09-23-2015 07:47 AM
Hi Jaime,
I have tried to restart the management network but same issue.
How can I verify ESXi settings?
Aristide
09-23-2015 07:52 AM
Through the ESXi interface, there's an option for the IP config.
09-23-2015 08:00 AM
ok but I don't see iIP config option
I can just configure management network.
09-23-2015 08:03 AM
Are you actually looking at the ESXi interface?? Or at the CIMC interface???
09-23-2015 08:13 AM
I don't know exactly, but according to the installation guide I'm on system customization step
