09-23-2015 11:13 PM - edited 03-19-2019 10:08 AM
If you have a CUCM 10.5.2 publisher and rebuild it (with same IP address, DNS etc) does the license MAC change ie do you need to order new licenses?
Solved! Go to Solution.
09-24-2015 08:16 AM
09-24-2015 08:20 AM
Then hard code the MAC address on your Pub/PLM virtual machine, you can simply hard code it to what it is set dynamically now, and the license will always remain the same.
09-24-2015 12:15 AM
In CUCM 10.X licenses are managed from PLM.
If you have a built-in PLM along the CUCM you may need to rehost your licenses.
If you have stand-alone PLM server then you dont need to worry about that you may just need to delete and add the instance again.
-Terry
Please rate all helpful posts
09-24-2015 07:02 AM
In addition to great answer by Terry (+5), it is best practice to set the MAC address of the PLM virtual machine statically, so that it never changes if you for example move the virtual machine, and thus the licenses will remain active.
09-24-2015 08:16 AM
09-24-2015 08:03 AM
Terry,
PLM and CUCM are co-resident in this case.
09-24-2015 08:20 AM
09-24-2015 08:50 AM
How do you hard code a MAC address?
09-24-2015 08:56 AM
On the virtual machine go to Edit Settings, locate the Network Adapter, edit it and you will see the MAC address is grayed out and set to Dynamic. Select Static and leave the MAC as it is, and save.
10-22-2016 12:29 PM
Hello Chris, I have a similar issue. In my own case, I reinstalled the cucm publisher but with a different ip address. How can I move the fulfilment licenses to the new plm?
Which Mac address is to be hard coded? Is it PLM or PUB?. Or both?
10-23-2016 08:42 AM
I am assuming PLM is running on your Pub then?
If so, the quickest solution would be to hard code the MAC address of the virtual machine for what the old PLM/CUCM was. Otherwise you can contact licensing@cisco.com to have then re-host it for you.
10-23-2016 09:10 AM
Thanks Chris. In other words, I should put the Mac address of the old plm/cucm in the new plm/cucm. Interesting! I got the gist
10-23-2016 09:12 AM
Correct, as the PLM licensing is tied to the mac address of the virtual machine of the PLM server.
10-23-2016 10:15 AM
Yea. Let me use this medium to ask you questions on MCU, VCS and cucm. I know MCU handles more video conference calls. Can MCU be integrated directly to cucm using sip trunk without the VCS? If so, can it work fine and do u have a link for configuration guide?
Can vcs handle few video conference calls without MCU? If one does not have H. 323 end devices, is there any need for VCS? Because am thinking that the major role vcs plays is to allow H. 323 devices to communicat with sip end devices and if conference call is needed MCU comes into play. So, if one does not have H. 323 devices, MCU can be linked directly to cucm. I don't know if am correct
09-24-2015 05:02 PM
Then there are two options; It seems preferable one is as per the nice tip shared by my friend Chris; you can try to hard code the mac address to your current dynamic value preserving the same and use that one while rebuilding the new server. Once you do a DRS restore, you may not need to rehost your licenses. I have tried this but it myself but I believe it should work fine.
Second option is to rebuild the server using the same credentials etc. but still you will need to rehost you license file - you can work it out with licensing@cisco.com.
Let us know how you go.
+5 Chris and Aman.
-Terry
