09-26-2015 01:44 AM - edited 03-08-2019 01:57 AM
i have configured a NTP server.and i want to configure cisco routers to only get time from NTP Server.i do not cisco routers to be as a NTP server so that they give time to other systems.
i have configured routers like this:
ntp server x.x.x.x prefer
but the problem is that when i set a router's ip address as ntp for another cisco router , the second router synchronizes it's time from first router that i want to be only a ntp client.
there is another program named ntpquery that can query time from ntp servers.when i configure a router , then the program query the time successfully.it means that the router is configured as ntp server.
how can i set the routers to be only and only a ntp client?
09-26-2015 03:21 AM
IOS offers a lot of options for hardening NTP.
This document gives a very good overview: Secure NTP Template
Especially the commands 'ntp access-group peer <acl>' and 'ntp access-group serve-only <acl>' shoud be useful to achieve the control you're looking for.
Command Reference: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/bsm/command/bsm-cr-book/bsm-cr-n1.html#wp5471302810
Rolf
09-26-2015 01:14 PM
Hello
NTP server x.x.x.x ( you are pointing to a authorative server and you are the client)
NTP peer x.x.x.x( use this between two devices as they are non authoritive with each other) they will agree on a time.
res
Paul
09-27-2015 04:16 AM
Hi Paul,
I agree on your explanations about the ntp peer and ntp server commands, but I don't see how they can be used to restrict time requests without additional configuration (that's how I understand the original question).
Rolf
09-27-2015 11:09 AM
Hello Rolf
On their own they dont.
ACLs or client authentication would be applicable approach, as yourself pointed out with the cco doc link
What I was pointing out is:
The server option is for a client to a reliable time source( thus it will be a client only)
The peer option is for a client to client with reliable time sources ( thus it can share its reliable time to other clients)
res
paul
