Cisco AnyConnect: Check Computer Certificate Domain Membership
Alisson C
Hello everyone,
I have an ASA5550, on which I have successfuly configured Anyconnect (Client version 3.1.10010) to authenticate with both Username/Password and User certificate issued by my internal CA.
What I'm actually trying to achieve is to allow only computer domain members to login to this VPN access. So users cannot connect to the VPN when they are in their non-corporate devices.
I know every domain member computer have a certificate issued by my internal CA. Is it possible to use this certificate to authenticate the VPN instead of the User Cert?
I only have cisco Anyconnect Essentials license.
Version 9.1(6)4
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 400            perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Active  perpetual
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
Security Contexts                 : 2              perpetual
GTP/GPRS                          : Disabled       perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : 5000           perpetual
Other VPN Peers                   : 5000           perpetual
Total VPN Peers                   : 5000           perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
Cluster                           : Disabled       perpetual
rvarelac
Level 7
Level 7
Hi Alisson ,
I think you can use the certificate matching feature under the XML profile of Anyconnect , make sure the certificate store field is selected as "all" . Also you  can limit the devices that can connect to the VPN with DAP.
See more information below.
XML features
https://supportforums.cisco.com/document/12549161/anyconnect-xml-preferences
https://supportforums.cisco.com/document/12550601/anyconnect-xml-settings
DAP files
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/115947-dap-adv-functions-00.html
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/108000-dap-deploy-guide.html
Hope it helps.
-Randy-
rvarelac
Level 7
Level 7
Hi Alisson ,
XML features
DAP files
Hope it helps.
-Randy-
Hello Randy,
Thank you for your answer.
That is exactly what I was looking for.
Best regards.
Alisson C
Its been a long time, but I would like to update this to say that new windows (7 and 10) when using UAC in high levels still are unable to read the machine certificates, even if the option "Certificate store override" enabled in the Cisco AnyConnect client profile.
After struggling with it for weeks, i found out that the issue is related to the users with no admin privileges not being able to read the private key on the computer identity certificate.
If you add the permission, it will work.
Since I have to do this on about 2.5k computers, I had to use a powershell script + GPO on windows that sets the permission.
After that, VPN has been working just fine.
We will check this out. We are having a similar issue. Thanks!
