Nexus 4001 high Rx Pause
i have a scenario include Bladecenter -->nexus 4001--->nexus N5K96UP--->MDS 9148--Storage
I am seeing a very high "rx Pause" on the Nexus 4001 side  portchannel connected to nexus 5000. Here is the output:
SW-4001i(config)# sh int port-channel 10
port-channel10 is up
  Hardware: Port-Channel, address: c08c.609c.269a (bia c08c.609c.269a)
  MTU 1500 bytes, BW 40000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  Members in this channel: Eth1/15, Eth1/16, Eth1/17, Eth1/18
  1 minute input rate 35640 bits/sec, 0 packets/sec
  1 minute output rate 188496 bits/sec, 0 packets/sec
  Rx
    6353997 input packets 6333875 unicast packets 11048 multicast packets
    310 broadcast packets 4237344 jumbo packets 0 storm suppression packets
    9153613971 bytes
    41648 Rx pause
    0 input discard
  Tx
    15469076 output packets 3773 multicast packets
    686 broadcast packets 14714882 jumbo packets
    31221537507 bytes
    0 input error 0 short frame 0 watchdog
    0 no buffer 0 runt 0 CRC 0 ecc
    0 overrun  0 underrun 0 ignored 0 bad etype drop
    0 bad proto drop 0 if down drop 0 input with dribble
    0 output error 0 collision 0 deferred
    0 late collision 0 lost carrier 0 no carrier
    0 babble
928 Tx pause
  0 interface resets
_______________________________
SW-4001i(config)# sh interface port-channel 10 counters detailed
port-channel10
  Rx Packets:                                     6356736
  Rx Unicast Packets:                             6336244
  Rx Multicast Packets:                             11421
  Rx Broadcast Packets:                               317
  Rx Jumbo Packets:                               4237563
  Rx Bytes:                                    9154435142
  Rx Packets from 0 to 64 bytes:                     7007
  Rx Packets from 65 to 127 bytes:                2086004
  Rx Packets from 128 to 255 bytes:                  9270
  Rx Packets from 256 to 511 bytes:                  6962
  Rx Packets from 512 to 1023 bytes:                 5981
  Rx Packets from 1024 to 1518 bytes:                 364
  Rx Packets from 1519 to 1548 bytes:                  42
  Rx Trunk Packets:                               6341124
  Tx Packets:                                    15472247
  Tx Unicast Packets:                            15458153
  Tx Multicast Packets:                              3878
  Tx Broadcast Packets:                               694
  Tx Jumbo Packets:                              14715681
  Tx Bytes:                                   31223603330
  Tx Packets from 0 to 64 bytes:                    90144
  Tx Packets from 65 to 127 bytes:                 745823
  Tx Packets from 128 to 255 bytes:                785839
  Tx Packets from 256 to 511 bytes:                 78299
  Tx Packets from 512 to 1023 bytes:               103157
  Tx Packets from 1024 to 1518 bytes:              773482
  Tx Packets from 1519 to 1548 bytes:              788476
  Tx Trunk Packets:                              15459562
  Rx Pause:                                         41648
  Tx Pause:                                           928
  SQETest                                             928
SW-4001i(config)# sh interface flowcontrol
Port       Send FlowControl  Receive FlowControl  RxPause             TxPause
           admin    oper     admin    oper
Eth1/1     off      off      off      off         0                    278
Eth1/2     off      off      off      off         0                    278
Eth1/3     off      off      off      off         0                    278
Eth1/4     off      off      off      off         0                    2582
Eth1/5     off      off      off      off         0                    278
Eth1/6     off      off      off      off         0                    278
Eth1/7     off      off      off      off         0                    278
Eth1/8     off      off      off      off         0                    278
Eth1/9     off      off      off      off         0                    278
Eth1/10    off      off      off      off         0                    278
Eth1/11    off      off      off      off         0                    278
Eth1/12    off      off      off      off         0                    278
Eth1/13    off      off      off      off         0                    278
Eth1/14    off      off      off      off         0                    278
Eth1/15    off      off      off      off         0                    274
Eth1/16    off      off      off      off         0                    272
Eth1/17    off      off      off      off         0                    278
Eth1/18    off      off      off      off         41648                104
Eth1/19    off      off      off      off         0                    0
Eth1/20    off      off      off      off         0                    0
Po10       off      off      off      off         41648                928
also you see sh run :
SW-4001i(config)# sh run
version 4.1(2)E1(1n)
feature telnet
feature lacp
feature fip-snooping
username admin password 5 !  role network-admin
username USERID password 5 $1$JY2o30Ad$tUi8chLhL0SAxnFaC6guH/  role network-admin
ip domain-lookup
ip host SW-4001i 192.168.200.1
hostname SW-4001i
policy-map type queuing policy-fcoe-bandwidth
  class type queuing 1p7q4t-out-q-default
    bandwidth percent 50
  class type queuing 1p7q4t-out-pq1
    bandwidth percent 7
  class type queuing 1p7q4t-out-q2
    bandwidth percent 7
  class type queuing 1p7q4t-out-q3
    bandwidth percent 7
  class type queuing 1p7q4t-out-q4
    bandwidth percent 7
  class type queuing 1p7q4t-out-q5
    bandwidth percent 7
  class type queuing 1p7q4t-out-q6
    bandwidth percent 7
  class type queuing 1p7q4t-out-q7
    bandwidth percent 7
class-map type network-qos class-fcoe
  match cos 3
class-map type network-qos class-non-fcoe
  match cos 0-2,4-7
policy-map type network-qos policy-fcoe
  class type network-qos class-fcoe
    pause no-drop
    mtu 2500
  class type network-qos class-non-fcoe
system qos
  service-policy type network-qos policy-fcoe
  service-policy type queuing output policy-fcoe-bandwidth
snmp-server user USERID network-admin auth md5 0xd12480fdd8d0bf8074815b83070e4f7a priv 0xd12480fdd8d0bf8074815b83070e4f7a localizedk
ey
vrf context management
  ip route 0.0.0.0/0 10.10.10.2
vlan 1
vlan 10
  fip-snooping enable
vlan 485
port-channel load-balance ethernet source-dest-port
ele-fwd pause rate threshold is 1000 pps
interface port-channel10
  switchport mode trunk
  switchport trunk allowed vlan 1,10,485
  priority-flow-control mode on
  fip-snooping port-mode fcf
  speed 10000
interface Ethernet1/1
  spanning-tree port type edge
  speed 10000
interface Ethernet1/2
  description balde 2
  switchport trunk native vlan 485
  speed 10000
interface Ethernet1/3
  speed 10000
interface Ethernet1/4
  speed 10000
interface Ethernet1/5
  speed 10000
interface Ethernet1/6
  speed 10000
interface Ethernet1/7
  speed 10000
interface Ethernet1/8
  speed 10000
interface Ethernet1/9
  speed 10000
interface Ethernet1/10
  speed 10000
interface Ethernet1/11
  speed 10000
interface Ethernet1/12
  speed 10000
interface Ethernet1/13
  speed 10000
interface Ethernet1/14
  speed 10000
interface Ethernet1/15
  speed 10000
  channel-group 10 mode active
interface Ethernet1/16
  speed 10000
interface Ethernet1/17
  speed 10000
interface Ethernet1/18
  speed 10000
interface Ethernet1/19
  speed 10000
interface Ethernet1/20
  speed 10000
interface mgmt0
  ip address 192.168.200.1/24
interface mgmt1
boot kickstart bootflash:/n4000-bk9-kickstart.4.1.2.E1.1n.bin
boot system bootflash:/n4000-bk9.4.1.2.E1.1n.bin
N5K96UP-1# sh int port-channel 10
  Hardware: Port-Channel, address: 002a.6ae6.7aa8 (bia 002a.6ae6.7aa8)
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Members in this channel: Eth1/33, Eth1/34, Eth1/35, Eth1/36
  6 interface resets
  30 seconds input rate 108904 bits/sec, 13 packets/sec
  30 seconds output rate 26016 bits/sec, 11 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 238.02 Kbps, 14 pps; output rate 39.28 Kbps, 11 pps
  RX
    70222975 unicast packets  30621 multicast packets  4935 broadcast packets
    70258531 input packets  137731035809 bytes
    64715012 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    30125787 unicast packets  144949 multicast packets  12932 broadcast packets
    30283668 output packets  44180775880 bytes
    21111539 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  6 interface resets
version 7.0(6)N1(1)
feature fcoe
hostname N5K96UP-1
feature telnet
feature udld
feature interface-vlan
feature lacp
feature lldp
feature vtp
clock protocol none
feature fabric access
username admin password 5 $1$LJ5WKtAc$voXI4bFYbC.alKLDI0Xp71  role network-admin
no password strength-check
ip domain-lookup
system qos
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type qos input fcoe-default-in-policy
  service-policy type network-qos fcoe-default-nq-policy
slot 1
  port 43-48 type fc
snmp-server user admin network-admin auth md5 0x35d624191b34e07e6c4da9079363ea9c priv 0x35d624191b34e07e6c4da9079363ea9c localizedke
y
snmp-server host 172.20.16.171 traps version 2c public udp-port 1163
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
ip route 0.0.0.0/0 172.20.16.254
fcdomain fcid database
  vsan 1 wwn 10:00:40:f2:e9:87:9f:d9 fcid 0x00ca0000 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:aa:81 fcid 0x00ca0020 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:9e:89 fcid 0x00ca0040 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a7:91 fcid 0x00ca0080 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:9f:dd fcid 0x00ca00a0 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:9e:8d fcid 0x00ca00c0 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a7:95 fcid 0x00ca0100 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:9c:d1 fcid 0x00ca0120 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:9c:d9 fcid 0x00ca0140 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:9d:31 fcid 0x00ca0160 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a7:81 fcid 0x00ca0180 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a7:f1 fcid 0x00ca01a0 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:85:b9 fcid 0x00ca01c0 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a1:51 fcid 0x00ca0200 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a9:b1 fcid 0x00ca0220 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a9:99 fcid 0x00ca0081 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a8:91 fcid 0x00ca0240 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:85:bd fcid 0x00ca0260 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:9d:35 fcid 0x00ca0280 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a9:b9 fcid 0x00ca02c0 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:a9:bd fcid 0x00ca0300 dynamic
interface Vlan1
  no shutdown
interface Vlan485
  no shutdown
  ip address 172.20.16.181/24
interface san-port-channel 1
interface vfc105
  bind mac-address 40F2.E987.9D31
  no shutdown
interface vfc106
  bind mac-address 40F2.E987.A7F1
  no shutdown
interface vfc107
  bind mac-address 40F2.E987.9CD1
  no shutdown
interface vfc108
  bind mac-address 40F2.E987.A9B1
  no shutdown
interface vfc109
  bind mac-address 40F2.E987.A151
  no shutdown
interface vfc110
  bind mac-address 40F2.E987.A891
  no shutdown
interface vfc111
  bind mac-address 40F2.E987.A9B9
  no shutdown
interface vfc112
  bind mac-address 40F2.E987.A999
  no shutdown
interface vfc114
  bind mac-address 40F2.E987.9CD9
  no shutdown
interface fc1/43
interface fc1/44
interface fc1/45
  channel-group 1 force
  no shutdown
interface fc1/46
  no shutdown
interface fc1/47
  no shutdown
interface fc1/48
  no shutdown
  switchport access vlan 485
  speed 1000
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/42
interface mgmt0
  vrf member management
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.7.0.6.N1.1.bin
boot system bootflash:/n5000-uk9.7.0.6.N1.1.bin
also   i   install  2 VM in the storage and communication between  those host are drop about speed 100 M instead 4g .
please help me about this issue.
mant thanks
Rajeshkumar Gatti
I am not very clear on the problem description but will try my best to answer it.
Rx pauses received indicate that the end host connected to po10 is receiving traffic beyond its capacity to handle thereby causing the NIC to send pause frames to the upstream device. This will definitely slow down the data transfer rate. You may want to see if the end host performance specs are not being exceeded in any way.
-Raj
Rajeshkumar Gatti
-Raj
Hi Raj
thanks for your support
i have a storwize connect to MDS by 4 I/O in the downstream .when I do config Qos for a Pww of a blade to Pww of storwize this low speed (10)M gets over 600 M and stop counter of rx pause in the 4001. I have 14 Blade and  I need a solution for automatically for 14 blade .also in port channel between MDS and nexus 5K I did config dedicate mode .in the scenario its better dedicate mode or share mode .and also how do I see congestion on the mds or interfaces ?
many thanks
Mohammad
Hi Mohammad,
My expertise on the MDS side is limited.I did discuss your issue with one of the TAC engineers in the MDS team and the recommendation is to have a TAC case open to troubleshooting this further.
Raj
