No more than 8 participants on the meet me conference
david.camus
I have a meet me conference configured on my Cisco 2901 as:
telephony-service
 sdspfarm conference mute-on 111 mute-off 222
 sdspfarm units 1
 sdspfarm tag 1 MEETME_CFB
 conference hardware
 max-ephones 16
 max-dn 16
 ip source-address 10.100.36.101 port 2000
 max-conferences 8 gain -6
 transfer-system full-consult
ephone-dn  1  octo-line
 number 1111
 conference meetme unlocked
But impossible to reach more than 8 participants. When the ninth try to enter the conference, he get a "busy call".
When I do a "show ephone-dn summary", I can see:
PORT     CH  DN STATE     MWI_STATE    CODEC    VAD VTSP STATE            VPM STATE
50/0/1   1   CONNECTED    NONE         g729r8     y  S_CONNECT             EFXS_CONNEC
50/0/1   2   CONNECTED    NONE         g729r8     y  S_CONNECT             EFXS_CONNEC
50/0/1   3   CONNECTED    NONE         g729r8     y  S_CONNECT             EFXS_CONNEC
50/0/1   4   CONNECTED    NONE         g729r8     y  S_CONNECT             EFXS_CONNEC
50/0/1   5   CONNECTED    NONE         g729r8     y  S_CONNECT             EFXS_CONNEC
50/0/1   6   CONNECTED    NONE         g729r8     y  S_CONNECT             EFXS_CONNEC
50/0/1   7   CONNECTED    NONE         g729r8     y  S_CONNECT             EFXS_CONNEC
50/0/1   8   CONNECTED    NONE         g729r8     y  S_CONNECT             EFXS_CONNEC
50/0/2   1   IDLE         NONE         -          -  -                     EFXS_ONHOOK
50/0/2   2   IDLE         NONE         -          -  -                     EFXS_ONHOOK
50/0/2   3   IDLE         NONE         -          -  -                     EFXS_ONHOOK
50/0/2   4   IDLE         NONE         -          -  -                     EFXS_ONHOOK
50/0/2   5   IDLE         NONE         -          -  -                     EFXS_ONHOOK
50/0/2   6   IDLE         NONE         -          -  -                     EFXS_ONHOOK
50/0/2   7   IDLE         NONE         -          -  -                     EFXS_ONHOOK
50/0/2   8   IDLE         NONE         -          -  -                     EFXS_ONHOOK
Any help would be great.
Thanks.
7 Replies 7
Jaime Valencia
With octo-line directory numbers, only one directory number is required for an 8-party meet-me or ad hoc conference. Up to eight select and join instances are supported.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmeconf.html
java
if this helps, please rate
Hi Jaime,
Thank you for your answer. Does it mean that I can't reach 16 participants with octo-line directory numbers ?
Thank you again.
I realize I miss end-part of the configuration:
telephony-service
sdspfarm units 1
conference hardware
max-ephones 16
max-dn 16
number 1111
ephone-dn  2  octo-line
number 1111
preference 1
would it work with two octo-line ephone-dn to reach 16 participants ?
Thank you very much for your help.
What does the dspfarm confg looks like?
java
Here the dspfarm profile:
dspfarm profile 1 conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum conference-participants 16
 maximum sessions 1
 conference-join custom-cptone jointone
 conference-leave custom-cptone leavetone
 associate application SCCP
I found the solution: need to configure "no huntstop" in the ephone-dn configuration !
Ok well, I found solution to reach 16 participants, but the weird thing is that my Cisco just "eject" some random calls sometimes.
Without doing anything, after 2 or 3 minutes I loose a call (15/16)...
Capacity of the DSP maybe?...
