I have Vulnerability comes in scan for openssh. Currently have openssh 8.0 version on firepower. can anyone suggest what version is good for firepower currently. Or is 8.0 ssh version is ok? Appreciate your response.
Hi fellow Professionals, we are planning to implement a VxLAN EVPN Multisite solution between 2 x customer DCs using N9ks as the Border gateways (BGW) / <No ACI>. The BGWs will be connected to their site local legacy Core and will connect back to bac...
Hi 1- can we have a dnac cluster with 2 nodes instead of three (budget restriction)?We currently have one node in production, but we would like to have a robust DNAC infrastructure and ISE before planning to move to SDA fabric.2-Do the nodes need to...
Good day,I am planning to get rid of the N5K Datacenter Fabricpath to be replaced with Nexus 9K.of course, VPC will be in place for the N9K but what will be the best replacement for the Fabricpath replacement.1- Migrating Cisco FabricPath Environment...
How can I overcome the DNAC token timing out when using Postman? I have created an environment within Postman with the DNAC variables like host, username and password. Right now the current token will expire after a set length of time and I have to ...
Hello everyone I am John and I am new in python. So I want to create my own app but I have faced a problem. This means I have some questions about it if anyone expert is available please help me.
Reaching out to see if anybody out there might have a memory or two regarding Waas reporting. I am trying to determine if my DICOM sessions are being optimized and find that I cannot believe the data I am seeing in CM. summary: Have a OE7541 waas ...
I just got a renewal cert from verisgn for an existing site that has it's cert expired. How do you get the renewal cert information onto the CSS. I have tried a few ways. But I have yet to succeed
I install a new Nexus N9K-C93180YC-EX and when i boot it first time, it boot it in ACI mode. I need NX-OS mode but i don't have any APIC. There is no NX-OS image on bootflash as well. Now when i trying to copy the image from USB to bootflash ther...
Since I got stucked a couple of times to upgrade a WAE in accelerator mode via the WAAS CM, I'm wondering which is the best way to do this manually via the CLI. The WAE is located via a VSAT connection, which is usually not that stable, so the CM is ...
OK, i have a problem and an wondering what the best solution is. Issue - We have 4 servers, A,B,C and D. They all between them run / support a website abcd.net On the GSS, we want to have them in the following answering pattern - Request to abcd.net...
There is no NAT related config on ACE, so I believe that load balance is not using source translation.On the backbone, there is route-map configured on the Server vlan. This route-map is used for "set IP next-hop", but I cannot understand the purpose...
