10-05-2015 02:00 PM - edited 03-08-2019 02:04 AM
Symtoms -iSCSCi traffic is dropping and Esxi's are getting disconnected frequently ,looked at the interfaces for individual host, I am seeing output errors and TX-pause frames increment
BY default flow control is enabled on TX and is disabled on RX ...Same I have been verifying the vmware team to provide the results of flow control configured at there side ? Any thoughts on this .
Rahul Mehta
10-05-2015 03:45 PM
TX pause accumulating on the interfaces is a common problem with 2232 series. They come very little buffer (4mb) and so they run out of buffer with high speed server, storage, VMs, etc..
The only way you can remedy this is to go to a different FEX. We had to replace ours with 2248PQ FEX. They come with 32mb buffer and we don't see anymore pause frames.
10-05-2015 11:09 PM
how to verify drops in buffers on fex ports ,Do I need to enter into CLI mode of fex and run the commands ,Also does enabling flow control on link level will help on this ...
10-06-2015 05:58 AM
Enabling flow control does not really help. We tried it but had no luck. To see the buffer details you need go into CLI on the FEX or just open a TAC ticket and they will help you with that.
HTh
10-06-2015 06:25 AM
Enabling flow control on the host side can help as it will respond to Tx pauses and stop sending traffic for a specific interval. Tx pauses are the outcome of the lack of buffers. There are commands to check for the drops on the fex but honestly it will not give you anything to help solve this problem.
Here are some of the common remediation steps
1)Maximise number of uplinks between 2232FEX and parent. This is to have ability to have more paths towards the network. Also it will help in having max buffers for N2H traffic.
10-08-2015 07:34 AM
I have checked from host end and flow control is enabled on the ESXI host ...we are further troubleshooting on this...
ESXI and storage team are suspecting below remediation step for same ..
