10-05-2015 09:01 PM
I found this log continue occur on CRS-1 Version 3.6.3. How should I do?
LC/0/5/CPU0:Oct 6 10:55:05 BKK-7: gsp[140]: %OS-gsp-3-MSG_ENQUEUE_ERROR : Process pkg/bin/plim_1p_oc768 (pid 81988) not picking up messages, 23791 msgs dropped. 20482 msgs pending, taking 4632008 bytes
Thank you very much.
10-06-2015 04:29 AM
hi tigma, it means that the linecard in slot 5 is not able to process messages from GSP (group services protocol). GSP is a multicast delivery type of methodology for the RP to send messages like FIB updates to multiple nodes via the EOBC (ether out of band).
This is likely a sw bug, but which one precisely is hard to say. This message is just the result (headache) for which the root cause (eg a heavy night out drinking) is not presented unless we have more logs surrounding this.
It may be hard to go back in time when it started since 20k messages have been enq'd already waiting process with a subsequent 24k dropped. It seems to hold quite a bit of memory also.
You could try to process restart plim_1p_oc768 (pid 81988) on LC 5.
or possibly reload the LC
xander
10-06-2015 08:00 PM
I don't see the process to restart.
RP/0/RP0/CPU0:u1#sho processes | inc pli
JID TID CPU Stack pri state TimeInState HR:MM:SS:MSEC NAME
399 1 1 40K 10 Receive 0:00:00:0270 0:00:01:0149 vi_config_replicator
399 2 0 40K 10 Receive 1507:30:54:0156 0:00:00:0002 vi_config_replicator
399 3 1 40K 10 Receive 0:23:36:0686 0:00:00:0768 vi_config_replicator
399 4 0 40K 10 Receive 498:07:59:0512 0:00:00:0042 vi_config_replicator
RP/0/RP0/CPU0:u1#
RP/0/RP0/CPU0:u1#sho processes | inc 988
134 6 1 48K 10 Nanosleep 0:00:02:0988 0:00:00:0735 cethha
RP/0/RP0/CPU0:u1#
The log occurs every 5 minutes. Then I try to reload LC, the log disappeared.
10-07-2015 03:26 AM
ah yeah the process would be on the linecard, it would have been show proc loc 0/5/cpu0 pipe include.
any case the issue seems resolved with the lc reload. if this happens again we'll need to investigate some more.
cheers
xander
