ASA - Anyconnect is not enabled afer reload.
marionikic
everytime my ASA is reloaded anyconnect is not enabled.
It has to be manualy enabled.
I have asa 5510 with version 8.4.2.
Florin Barhala
Level 6
Level 6
So you're saying that after you reload you have a different configuration then before?
Can you make a file compare of the configs before and after the reboot and see what line is missing if the case?
Florin Barhala
Level 6
Level 6
Only thing I need to do is to check mark on "Enable CIsco Anyconnect VPN CLien access on the interfaces.."
It is always dissabled after reload.I susspect it's a bug.
It might be a bug, still I am curious about that configuration files diff.
CLI line should look like: anyconnect enable
CLI looks like this:
ciscoasa5510# show running-config | beg anyconnect
 anyconnect-essentials
 anyconnect image disk0:/anyconnect-win-3.1.05160-k9.pkg 1
 anyconnect enable
System image file is "disk0:/asa842-k8.bin
I can not perfor restart.ASA is in production.
